Results 1 to 8 of 8
    osh73's Avatar
    Dec 2015
    Default W906 2.2L 95KW remove DPF
    Good evening how you doing can help to remove (DPF catalyst)
    SPRINTER 313 W906 2006 2.2 l 95kw EDC 16c31-6+ CAN
    I his method removed the DPF+EGR (( diagnostics no errors but CHECK blinks and smokes
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    Did you reset DPF with ori file? You need to reset First than flash
    Wysłane z iPhone za pomocą Tapatalk
    DSG TUNING
    File Service
    osh73's Avatar
    Dec 2015
    Reset DPF (to remove a diagnostic error code)
    I think it is.
    maajkii's Avatar
    Mar 2017
    Quote Originally Posted by osh73 View Post
    I think it is.
    Reset Soot...
    DSG TUNING
    File Service
    osh73's Avatar
    Dec 2015
    thank you tomorrow I will unsubscribe.
    osh73's Avatar
    Dec 2015
    STAR Connect c4 -data adaptation reset.
    read the original file ((and remove DPF ))
    no errors, but flashing the check.
    please help!
    aem's Avatar
    Jun 2014
    snowboarding on the mountain
    how you remove dpf from soft?
    FILE SERVICE
    REMAP+ dpf-egr-vsa-scr-lambda...cars/buses/agriculture
    Genuine WinOLS user
  8. The Following User Says Thank You to aem For This Useful Post:
    pike (28th November, 2017)
    osh73's Avatar
    Dec 2015
    if you know of can you please.
