Hi ,
did you manage to solve the issue with flashing spanner?
I have DSG 7 DQ200.
The gear box works properly but there is sometimes ERROR P17BF.
I can remove DTC - it doesn't exist during checking the errors by VCDS.
But I have a problem - This symbol IMG_1815.jpg.c5cc496186cdb7b4a7adfc1de355e7d8.jpg is flashing instead D (or P R N) when error appears.
Can anybody switch it of ???
I attached ori and 2 not working solution (not dtc but key flashing).
Tnx.
Hi ,
Found my post helpful?
Just press "THANKS".
006079 – Hydraulic Pump P17BF – 000 – Play Protection – Intermittent Freeze
So i think there is a problem with the mechatronic unit .
Here one example : https://m.youtube.com/watch?v=B9VUeQsOrQ0
sometimes the leak is not as big, waldi probably solved this but here is the correct file for you
Could you share mod. no problem to pay.
