    Trstenik - Thun
    Default MB Star C3 HELP NEED
    Hi friends ,
    Need help or support fixing my MB Star c3 mux
    Voltage on laptop said 1.1 volts!!!!
    I made Ceaser test and i got these errors:
    D2 serctl1 2003dsr/dtr lines at uart 1 not connected
    D2 power battery voltage kl30=00.7 V
    D2 power ignition voltage kl15=00.3 V
    all other tests are OK
    Thanks in advance
    Trstenik - Thun
    Nobody had same problem?
    Trstenik - Thun
    Solved!
    Apr 2017
    hi mikroel
    I have the same problem with MB Star C3
    My device does not see voltages and has a UART error
    Everything is exactly the same as yours
    Please tell me how you solved your problem?
    Apr 2022
    Please, post the solution
    Dec 2010
    Take photos of the two PCB and I'll show you what to check
