    Jan 2013
    Default MB C220 delphi DCM3.2 dpf off MPC
    Need some help with dpf off solution for this ecu, or i would appreciate if someone with tested solution could check my file. It was done with swiftec, but car lost diagnostic capability and eventually next day didnt start anymore. With original MPC car is working again, if anyone can give a hand, or see if the file is wrong and sell me a working file, its fine too. Original files attached... Tks
    kiriki6969's Avatar
    Madrid
    Test and report
    Jan 2013
    thank you kiriki, i already a file to test aswell, if it doesnt work i will try yours. Tks you so much for helping
    Jan 2013
    with this file, car started the first time, but after switching ignition off, it didnt star again. Also it keeps sending some type of signal maybe to a relay, you can hear a noise every 30sec. Do you have any idea what this might be?
    Also its giving a bunch of DTC codes, please see attachment, and you cant delete them, it say "impossible to erase codes"
    kiriki6969's Avatar
    Madrid
    calculate checksum......
    principal problem
    Jan 2013
    just now checked this topic again, yes problem was solved right after my last post, it was a bad cks done with ktag. Wrote file with CMD and all was fine, including the initial swiftec solution
