Hello guys,
I deleted the FAP from this 159 by using bit switch off procedure, but maybe I did something wrong because the car smokes a lot and does not work well.
Although the FAP has been materially eliminated, it seems that it continues to regenerate.
Before writing the map, did not reset or change the new fap ... could the problem depend on this?
Can anybody give me a hand? thank you.
I attached file ori and switch off
DSG TUNING
File Service
Test and report
hi guys, I have not tryed this map because the 159 has eaten the flap swirl.
Now it's with the head open, so I wanted to disable the swirl too.
Could someone delete swirl from the map? thank you
dpf off switch not work, Swiftec and asc not work, better they cut 50% table dtc.....
FILE SERVICE
Solution one
one of them will work 100%
Hi, this is ori file.
I need FAP OFF and SWIRL OFF.
Tx a lot
giary74 (11th January, 2018)
Here are your files
