Page 4 of 4 FirstFirst 1234
Results 46 to 56 of 56
  1. #46
    Meat-Head's Avatar
    OK - was thinking earlier - what about getting an old diesel pump - couple it to the injectors - then you have instant control of it - remove the middle out the solenoid plunger and stick a fan/motor to blow the hot air and turn the pump.
    will be great untill it clogs up.
    Meat.
  2. #47
    Liteace's Avatar
    Mar 2009
    On a rock
    Meat.
    Spraying it in is no good, it'll get to hot and melt everything, its drip feed only, as for clogging up i think a diesel pump + injectors pumping used engine oil will last in about 3 mins if your lucky
  3. #48
    Meat-Head's Avatar
    Quote Originally Posted by Liteace View Post
    worth on theroy it was somthing to do with that martin lucifer-king bloke
  4. #49
    Top Poster djorgensen's Avatar
    Cardiff, UK
    waste diesel filtered into a disel pump is fine
    i converted a friends common rail van ro run on it, no problem
    as for waste oil heaters, i considered some of the models listed on ebay, and even making my own
    however i have a thermobile at500 coming on tuesday, i will report if it works
    I'm a guy trying to make a living
  5. #50
    Meat-Head's Avatar
    Quote Originally Posted by djorgensen View Post
    OFF TOPIC:-
    How, or did you just put an extra 26 fuel filters on it?
  6. #51
    Meat-Head's Avatar
    ON TOPIC:-
    If your avrudge car is say 88KW so if you strip car down SI you only have engine/box fwd connect to driveshafts a dunk a d/or (iShit Failiure) dyno or water pump so its going against its self, therory you have 88kw heater that will warm the radiators round workshop very quick, then once every ???? Restart to reheat.
  7. #52
    Meat-Head's Avatar
    On topic:-
    needs a little refining, like comments say blower and/or smaller holes high pressure drip pipe to make a mist, use airline to pressure the oil
    https://m.youtube.com/watch?v=_SWnLeXatrw
  8. #53
    Liteace's Avatar
    Mar 2009
    On a rock
    That would for sure keep the workshop warm, may get a bit smokey
  9. #54
    Meat-Head's Avatar
    Think if got proper fuel and refined will be ok
  10. #55
    Do not use petrol or diesel engine to warm liquids. They have poor efficiency for that task.
    The only intelligent use for them is to carry weight from A to B without doing burnout (pure rotation).
    ______
  11. #56
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Got one of these 2 years ago great heater http://pages.ebay.com/link/?nav=item...d=271555419874
    Sent from my iPad using Tapatalk
