Try and report.
remember rep+thenks
Try and report.
remember rep+thenks
no work... anyone can help please?
regards
DSG TUNING
File Service
hi... i try but light still ON and so much smoke
Have you solution?
regards
for you friend .. do not forget to calculate checksum .. good luck
try this file
yeah, send for him eleven file and still not work. You have dtc with temp sensor?
FILE SERVICE
Thanks :-( but nothing work...
VOLTECHCAR, have you any idea?
Best regards
yes write ori file, check what temp sensor is destroy, simulated temp sensor 1k ohm. Than start emergency regeneration, when filling the particuler filter fall below 12 percent erase all dtc and I do you file good solution. You must have max 12 percent becuase never fillter dissapear when ecu have bug sensor with dpf
FILE SERVICE
No other solution by Dump?
regards
this is siemens not bosch, with bosch I emulated temp sensor but not in ppd
FILE SERVICE
Problem SOLVED, Thanks a lot :-)
its good to tell us how you did this
DSG TUNING
File Service
