Results 1 to 5 of 5
    ireland
    Default 2012 Peugeot Partner edc17c10 dpf off
    HI
    i have peugeot partner year 2012 1.6 HDI edc17c10
    i have dtc
    p0460 Fuel level meassurement.Variation outside tolerance
    P1434 Multiplex additive pump . pump fault
    P1435 Multiplex additive pump CAN network fault or pump fault
    engine without power
    i try many solution egr off fap off and aditif pump disconect
    but same.
    i need good solution egr off dpf aditif off dtc off
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Try this one mate. I removed dpf with additive pump, egr by hysteresis should be disconnected. Test and report . Pass pm
    Dont forget thanks and reputation buttons
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  3. The Following User Says Thank You to Ignasvw For This Useful Post:
    mendox (8th December, 2017)
    ireland
    Quote Originally Posted by Ignasvw View Post
    hi
    ecu no fault but i get on display ENGINE FAULT
    johak's Avatar
    one file from me
  6. The Following 4 Users Say Thank You to johak For This Useful Post:
    chafik4051 (1st June, 2020), mendox (8th December, 2017), pericadex (15th January, 2020), sonic 1989 (10th December, 2017)
    ireland
    johak you file working perfect.
    thank you very much.
