Is it possible you got the hazard lights plug and power button mixed up that burnt the button
understand the button gives out two negatives
Hi , again .
I hope i'm close to find the problem,i just change the Gem module and i don't have error , but now the ignition is on and the central looking work only to open on the remote key.
I burn 2 start button till now , because when i press start there i have (+) permanently i ve just look on diagram and in the button wires i must have only( -) and (+) take only whwn i press the button to start .
From were came Signal from start button, wich Module below?
Best regrads
catalinosonesti (12th June, 2022)
I see were it was problem .
The big confuse with Buttons, to start ( hazard ) i must have 6 wires , i have only 4 , why .? Because i put wrong the jack wrong , it was from the heater chairs on the left side the same Format like Power button.
Now After more investigation i have IGNITION , but also key not reconize , and no start .
Meat-Head (20th June, 2022)
Hi , again .
What i do ?
When i put back radio i make a big mistake and i plug the ignition conector on the heat seat wich it was the same only diferense was the coulor and wires ( 6 ignition and 4 seat ).
I was burn 2 butons ignition till i see the mistake, i put New button and i have now ignition , but the car still no start ,and i have in dash key no reconize.
I will put the error here maybe someone can help me how i must to do this procedure and wich toll can do this syncro.
Best regrads
