br.balazs (4th May, 2019)
Hi, i have peugeot boxer 3 2016yrs. 2.2 engine. Cmd gave me id for sid208. I read this via obd. Now i have this file and i need to raise speedlimiter, Now its set to 110-115. Tried to find in file, but i have too much options for it. Maybe someone done this job on this ecu? On ford i now its 4x speedlimiter in file. but how on this ecu? Regards. I attach ori file. And maybe i need full bdm to do this?
never done this car but check adress 52d8
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
Hi, auto without DPF?
DSG TUNING
File Service
DSG TUNING
File Service
im sure this is with dpf. now i have full read with eeprom and irom. Tried to use peugeot diagnostic, but no luck. It has only older boxer version. Tried to connect like citroen, it found ecu, i choosed sid208, i opened ?set speed limiter? section. But then it gaves me communication error. In BSI speed limiter is deactivated. In past this car was used in car rent Firm. I attach eeproms and irom
have you found solution y
et?
