    Jan 2013
    Montevideo, Uruguay
    Default P2015 VW TIGUAN MED17.5
    Hola, ¿cómo sabe alguien cómo eliminar el dtc?
    ecu es 06J9060AB MED17.5
    DUMP:
    Andrei2015's Avatar
    Oct 2015
    write in english and maybe someone will help you
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
    on allmost every petrol
    Jan 2013
    Montevideo, Uruguay
    P2015 dtc off.
    I want to delete the code P2015
    VW TIGUAN 2.0 TSI MED17.5 06J9060AB
    johak's Avatar
    here you go
    Jan 2013
    Montevideo, Uruguay
    Thank you very much for the response, my regards to you.
    As soon as you try, comment on how it went.
    Thank you very much.
    sebasapri's Avatar
    Apr 2015
    Balcarce
    Hi mate !
    I have the same problem with AUDI , 2015 the flaps is gone.
    can you delete .
    thanks very much
