    Mar 2016
    Default Fgtech Galletto 4 v54 clone working need advice
    Hello guys after owning a MPPS cable and Galletto 1260 cable I realised I need a better tool I now have fgtech Galletto 4 v54, I've got a small laptop which I've put windows xp on and installed the driver for Galletto and it is working, I'm trying to read from OBD port on a Bosch edc16c39 and on k line it asks to read with jtag but on can protocol it says no connection please turn of dashboard so would you suggest that the Galletto is not working?
    Although it shows on EODB software 12.8volts from ecu, so it must be working?
    Also need pin out for jtag on Bosch edc16c39 with Galletto v54 clone thanks guys
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    Read edc16c39 via BDM
    this ecu isn't readable via OBD, BDM is fast and safety way.
    DSG TUNING
    File Service
  3. The Following User Says Thank You to maajkii For This Useful Post:
    speedy100 (17th December, 2017)
    Mar 2016
    Hello there mate I've seen videos of Galletto v54 reading it by jtag, have you got a pin out for jtag i could use please and also becuse its showing 12.8volts through the software do you think it is working thanks
    Does anybody have diagram for the Galletto wires colour
    Nov 2017
    hi. I need pdf file for wire connection guide.
    Nov 2017
    hi
    Jun 2013
    EU
    There is a folder called documents inside the fgtech installation path. There you find how to bdm any edc16 ecu.
  8. The Following 2 Users Say Thank You to morgano For This Useful Post:
    bobolin4o (30th December, 2017), maajkii (30th December, 2017)
