victormarinho67 (24th May, 2018)
Good morning .
I have Smok Update "BSI CONTINENTAL 6/2015"
I change Km in Citroen DS4 10/2015, Now the car does not start !!
Can someone explain step by step how to solve the problem with Smok software?
Thank you
pierre renault (17th December, 2017)
It is all working, also from startup but, no motor does not work. The way to recover with Smok but I do not understand the explanations they gave me. Just someone with the Smok psa continental 6/2015 program that can help me!
esse (14th February, 2020), pierre renault (17th December, 2017)
Repinator (19th December, 2017)
smok have lot of beug in continental bsi 06/2015 ...
i crash 2 cars ( with & without keyless )
after crash, you must write data flash stored in uhds/files and write configuration bsi file backup to engine start but you win lot of DTC errors
yes it's true, if you are attempting do by OBD you need to reflash BSI after... best and safety way is to remove BSI and do it on the bench, like a "LEGEND"
i had same brobleme with same car and no solved at this time
for me fls corupted when reading with smok and no start
with help of DK member (thanks again) car start but not all work fine.....remote or ligth.....
