Results 1 to 12 of 12
    pierre renault's Avatar
    Jan 2013
    Default Help Problem DS4 for Update Continental 6/2015 SMOK
    Good morning .
    I have Smok Update "BSI CONTINENTAL 6/2015"
    I change Km in Citroen DS4 10/2015, Now the car does not start !!
    Can someone explain step by step how to solve the problem with Smok software?
    Thank you
  2. The Following User Says Thank You to pierre renault For This Useful Post:
    victormarinho67 (24th May, 2018)
  3. #2
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Jul 2009
    In my immobox...
    1st of all explain the problem. BSI die? Can you have ign on? Don't see key anymore?
    Did you save bsi configuration before?
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
  4. The Following User Says Thank You to lupu_sandu For This Useful Post:
    pierre renault (17th December, 2017)
  5. #3
    Jan 2013
    It is all working, also from startup but, no motor does not work. The way to recover with Smok but I do not understand the explanations they gave me. Just someone with the Smok psa continental 6/2015 program that can help me!
  6. The Following User Says Thank You to pierre renault For This Useful Post:
  7. #4
    drpeter's Avatar
    Dec 2009
    The Netherlands
    Quote Originally Posted by pierre renault View Post
    Is it a keyless system? I know there is bug from abritus with a keyless system, which suppodes to be solved now by abritus, smok copies abritus so i think he still has the bug in his software.
  8. The Following 2 Users Say Thank You to drpeter For This Useful Post:
    esse (14th February, 2020), pierre renault (17th December, 2017)
  9. #5
    Sep 2009
    If u read smok instructions it says if car not start read pin. Program keys. Program pin
    Sent from my SM-G950F using Tapatalk
    Don't forget to hit thanks button
  10. #6
    Nov 2010
    Quote Originally Posted by javyb View Post
    where you find smok instructions?
  11. #7
    Sep 2009
    Quote Originally Posted by Repinator View Post
    At end of programming where it Says write I'm success it tells u what to do if car not start
  12. The Following User Says Thank You to javyb For This Useful Post:
    Repinator (19th December, 2017)
  13. #8
    peko's Avatar
    Jan 2010
    smok have lot of beug in continental bsi 06/2015 ...
    i crash 2 cars ( with & without keyless )
    after crash, you must write data flash stored in uhds/files and write configuration bsi file backup to engine start but you win lot of DTC errors
  14. The Following User Says Thank You to peko For This Useful Post:
  15. #9
    Cllau's Avatar
    Mar 2017
    where friends need me
    yes it's true, if you are attempting do by OBD you need to reflash BSI after... best and safety way is to remove BSI and do it on the bench, like a "LEGEND"
  16. #10
    peko's Avatar
    Jan 2010
    Quote Originally Posted by Cllau View Post
    yes but is very hard to separate both PCB
    have you pinout ?
  17. #11
    esse's Avatar
    Jan 2010
    france
    i had same brobleme with same car and no solved at this time
    for me fls corupted when reading with smok and no start
    with help of DK member (thanks again) car start but not all work fine.....remote or ligth.....
  18. #12
    peko's Avatar
    Jan 2010
    Quote Originally Posted by esse View Post
    you must go to dealer and telecode it to solve it or telecode yourself if you can with diagbox
