Results 1 to 15 of 15
Thread: easiest option
    Aug 2008
    Norn Iron
    Default easiest option
    hello
    I have a eurovox that worked like a dream. I moved into a new place but it doesn't have cable. I get digital freeview by connecting to aerial socket in wall. I was told this is satellite feed. If I connected open media to this socket can I pick up channels?
    Vrgn describe these new build apts in Belfast as a non cabled area and we can't put up sky satellite dishes so I don't know what to do
    Any help is much appreciated
    DK Veteran clit-eastwood's Avatar
    Aug 2008
    Ask your neighbours if any of them have sky, if they do, you will find that there is probably a communal dish on the building somewhere. A lot of apartment blocks are not allowed to have individual dishes, so they all share a comunal dish.
    Aug 2008
    Norn Iron
    do you mean to get a sky basic package in? Any chance open media would work via ( satellite) aerial socket?
    Aug 2008
    eurovox wont work with a sky dish, you would have to get a compatible box for sky
    Aug 2008
    Norn Iron
    Quote Originally Posted by clit-eastwood View Post
    yes, I will get open media box. Just hoping it might have been able to pick up a feed from satellite that currently provides freeview
    Aug 2008
    Yes that would work, also download the firmware to get all the rest of the channels.
    Good luck
    Aug 2008
    Norn Iron
    Good luck
    thanks. 500cs ordered. Fingers crossed
    Aug 2008
    Norn Iron
    ok, got the box, did a scan on my satellite feed, only satellite name found was something like PANAMSTAT 1R
    is this an actual satellite found or a default?
    Apr 2008
    if you are connecting it to a communial dish then more then likely its facing 28.2% what you do is select 28.2 or Eurobird from the list. make sure nit option is selected (if using the neutrino image) and do another scan
    Aug 2008
    Norn Iron
    Quote Originally Posted by max_gee View Post
    How do I select the satellite? I only get PANAMSAT 45 degrees. No other choice. I was using directional button
    Am I doing something wrong?
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by qwertyballs View Post
    you will probably need to enter your longitude and latitude , in your sat settings for your reciever to understand where the dish is.
    Worldwide map search, route finder and travel directions - powered by Multimap that will help you find it.
    Aug 2008
    Norn Iron
    Quote Originally Posted by aftermath View Post
    ok thanks!
    Would this get entered in setup? Manual talked about setting language, time etc but mine was already set
    All help appreciated
  13. #13
    aftermath's Avatar
    Mar 2008
    cant remember exactly, as i dont have open media right now, but think its in the sat location, or DISEq2 . something like that, should be one of the first options when you have re flashed box and re started
  14. #14
    Aug 2008
    Norn Iron
    what is reflashing? How do I do it?
  15. #15
    Aug 2008
    Norn Iron
    All sorted. Thanks max_gee!!!
