Hie fellows,
I need assistance with a Mazda 3 Immo Pin Code,i want to program a key but cant get the pin code from the cluster.can i get pin by vin or just cluster dump and post here?thanks in advance.
Hie fellows,
Here files attached, please rename from rar to bin, was failing to upload as binmazda%203%20eepron%20dash8x.rarmazda%203%20eepron%20dash16x.rar
Sent from my SM-N900 using Tapatalk
For models with PATS3+ and later is possible to calculate Incode from Outcode. Incode is required for accessing security procedures (Coded Access) with IDS and other diagnostic equipment. To calculate of Incode you need to enter 6 or 16 chars Outcode from diagnostic tester. For Coded Access which require 8 chars Incode you need to enter full 16 chars Outcode, dash or space separated. Example of Outcode: 0040 ABCDEF 123456
For models with MECS is possible to calculate PIN code by serial number from immobilizer unit. Enter 10 digits S/N from label of Lucas immobilizer. It begins with 4, 5 or 6.
To calculate PIN code by dump you need to locate and read following type of EEPROM, MCU or Flash (depend of car model and year):
Immo Box - HC705P3, HC705B8, HC705B16
ECU - M951G, TC97101p, 77005, 77012, 77014, 25040, 24C01, 24C02, 93C56
I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
