Results 1 to 3 of 3
    mexanico1971's Avatar
    portugal
    Default Citroen C5 2,2 hdi EDC15c2 additive ECU and FAP problem
    Hi folks
    I have this problem on a Citroen C5 2,2 hdi , that is drive me mad , I can"t delete the Dtc related width additive ECU and MAf P0110 .
    I made fap off by switch but no luck after some miles Safe mode and these DTC"s
    DTC"s
    P0110
    P1446 additive level
    p1435
    additive PUMP
    P1442
    additive ECU
    P1425 CAT 2 temp
    P1447 FAP hole
    I have done before all procedure
    Can some delete DTC"s ?!
    Or give some ideas about this problem
    Thank"s in advance
    Brs
    My work is my life ART TECH GARAGE
    portugal
    No one ??!
    portugal
    No one have solution for , Diff.Pressure Sensor and Temperatur Sensors Disconnected :-(
