Results 1 to 2 of 2
    dimitar's Avatar
    Default Ducato 2.3 edc16c39 TVA off
    Can someone please turn TVA off
    Fault code p0638
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    2dv0ly8.jpgThis is my solution how i solve problems with tva on this engine. If you will disconnect TVA you will have limp mode. I deleted 0638dtc, now you need to remove tva and cut that moving mechanism and put all back. TVA MUST BE CONNECTED. I add a photo which part you need to cut. Regards, no pass. Use thanks and reputation if i helped you
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
  3. The Following 2 Users Say Thank You to Ignasvw For This Useful Post:
    Apsik (1st August, 2018), dimitar (22nd December, 2017)
