Its possible but not with obd read. One map for popcorn is missed, Ofc it can be done on duration or torque. But best is svrl available in BDM read.
EGR off is possible, o2 sensors too.
Wysłane z iPhone za pomocą Tapatalk
DSG TUNING
File Service
teerak2uk (28th December, 2017)
Hi, not 1CC83C for example in this file? This is OBD read.
DSG TUNING
File Service
walshy155 (28th December, 2017)
Thank you very much maajkii
in the sample file of mancioks 1CC83C is a revolution limiter
maybe it will work, try
Hello people, I've put hard cut limiter on my car 1.9 16v mjet Bosch edc16c39, the method is injection quantity and I get fuel temperature to high fault code on the limiter, although fuel temperature is about 15 degrees, I'm guessing the only way around it is to use SVRL method?
Did you tried change value that i wrote before? Also You can try torque limiter cut. Put Your files here it will be easier
DSG TUNING
File Service
Hello people can you check my map file to see if the map is any good, it is stage 1, EGR off, O2 off and hardcut limiter, the limiter produces fault code like I mentioned before if somebody could check it that would help a lot and Id be greatful
