Results 1 to 9 of 9
    Mar 2016
    Sweden
    Default renault fluence 1.6i synchronization
    hi all, pls help correct synchronization renault fluence 1.6i k4m 2011
    0473 6143 4746 8270 29D1 04BF 1C6E C231 9809 3C4C
    VF1LZBR0545664457 PLEASE GIVE OUT CODE
    MartiLer's Avatar
    Dec 2016
    Read NEC BCM , and eeprom ECU.
    Bllinda's Avatar
    Baltic
    this solution is with the dealer.
    Quote Originally Posted by sonic 1989 View Post
    Uvi, na sei den....
    today
    A topic that interests me
    jackeldestripador's Avatar
    S.A.
    Hi pals! can somebody help me? I have this Fluence out of sync for some flat bat. I have reader Ecu eeprom and bcm mcu. somebody knows how to sync?
    UCH 284B13208R - NEC MCU
    ECU V29006869B - 95640
    MartiLer's Avatar
    Dec 2016
    Yes, see the mail.
  6. The Following 2 Users Say Thank You to MartiLer For This Useful Post:
    gege974 (28th October, 2018), jackeldestripador (29th October, 2018)
    MartiLer's Avatar
    Dec 2016
    sync ok......
  8. The Following 2 Users Say Thank You to MartiLer For This Useful Post:
    immooff (12th April, 2021), jackeldestripador (29th October, 2018)
  9. #7
    Dec 2015
    Quote Originally Posted by MartiLer View Post
    sync ok......
    Hi friend, you can send password.
    Thank you
  10. #8
    Dec 2018
    in the case of battery discharge and loss of synchronization, it is enough to rewrite the keys. canclip, RET cope with work
  11. #9
    Mar 2011
    Default synchro
    Hello !
    Does anybody knows where the synchro i located in this dump form BCM
