Results 1 to 12 of 12
    Aug 2015
    Default Peugeot Boxer 3.0HDI EDC16C39 TVA off
    could somebody help me with P0638 DTC and TVA Off? Because if i dissabled DTC car has no power, i think its like Iveco need somethink little more off.
    Aug 2015
    nobody have solution ?
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    I have solution, but you need to plug tva
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    johak's Avatar
    if you want to try this.
    disconnect tva and see for limp mode
    if there is dtc but no limp mode dtc can be deleted
  5. The Following 2 Users Say Thank You to johak For This Useful Post:
    Ignasvw (4th January, 2018), shooperis (4th January, 2018)
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    with tva disconnected car will have limp.
    My method on this craps.
    1) delete 0638dtc
    2)remove tva and cut that part from picture i attached.
    3) put back tva and connect the plug.
    You need to cut it. make it like blank
  7. The Following User Says Thank You to Ignasvw For This Useful Post:
  8. #6
    Aug 2015
    Quote Originally Posted by Ignasvw View Post
    1) delete 0638dtc
    Thanks Ignas for your solution, but exists solution with a disconnected connection.
  9. #7
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    If you will find it share with me. regards
  10. #8
    johak's Avatar
    he must try my file and report
    I have not deleted any dtc
  11. #9
    Aug 2015
    Quote Originally Posted by johak View Post
    Thanks but your solution i think will not work, you disabling DTC healing, but i hasnt dtc if dissabled from table. Need make blank (zero all) map and switch. Maybe you have damos file for this ecu ? i have iveco solution with TVA off, i could share it.
  12. #10
    Aug 2015
    Second solution is to dissable limp mode limiter, but i dont want do this :/
  13. #11
    johak's Avatar
    i have not touched limp mode limiter
  14. #12
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Use my solution. its tested and working
  15. The Following User Says Thank You to Ignasvw For This Useful Post:
    johak (4th January, 2018)
