P0299 it's low boost
And where is the ori file?
Maybe we must to have all files for all ecus in the world, or we must to search it, because you are too lazy to post it?
As the title of the topic says - you want to achieve EGR delete. Why the hell you've zeroed the MAF linearization map?
Regards...
Lol, properly confused with hysteresis map
Yes I'm confused with hysterisis map
How I need to process Morgano ??
Make the map 32x1 and the values up and down to it back to original.
pike (7th January, 2018)
this file was made by me egr-off (by hysteresis), dpf-off, maf-off and one dtc
you said it worked, what is the problem with egr?
EGR and DPF off are fine.
But... i don't think, that "MAF off" will be OK with simple zeroing MAF linearization and seting the timers for non-detecting the faulty MAF.
With this scenario The ECU will not detect the broken/missing MAF and will take for sure the values from the linear. map into account...
I have not tested maf off on my car before he said it worked
What is the best way to do it !!!!
It worked a few time and I got DTC : P0299-000 and I thought It was ans egr issue ?!
My mistake ?
I'm not criticizing Johak tried to help me !
I'm in good form today attached my ori file ...
Need help !
MAF worked on your car ?
