Results 1 to 11 of 11
    Feb 2013
    Default pcr2.1 VCP boot read not working
    trying to read PCR2.1 by VCP (VAG CAN PRO genuine) in boot, but not working. Actually I need only MCU ID.
    Getting communication on bench, can read flash file.
    In ECU flasher menu selecting PCR2.1 EEP.
    Switching of power supply, and connecting wires and resistors by chematics (strange that one resistor marked in red and looks like "+" sign there..hhhmm)
    trying to read by "Boot MCU".
    When trying to read always getting answer NoBootACKFrm, the same answer when reading with switched off power supply or disconnected OBD plug.
    ECU on bench using 0.4A and with resistors connected 0.2A (looks like it should be in boot mode), when trying to read "BootMCU" can sea blinking for split second CAN-H and CAN-L LED's, looks like there was attempt to read, but amperage staying the same 0.2A.
    p.s. on Win XP diagnostics works, but not recognising ECU on bench. Win7 x64 reads ECU flash on bench.
    Any ideas?
    Kind regards
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    Did you unlock ecu?
    Wysłane z iPhone za pomocą Tapatalk
    DSG TUNING
    File Service
    Feb 2013
    yes, unlocked before
    Feb 2017
    why you dont read obd
    Feb 2013
    "Actually I need only MCU ID"
    not too many tools can provide this data, for flashing I have other tools.
    Feb 2013
    can't ID ECU and even not able to reflash without ID.
    ECU is bricked, end of story.
    Sep 2016
    flashing frf and get up
    FILE SERVICE
    Feb 2013
    vcp cant connect to it, vas cant connect on table with it.
    Sep 2016
    use smok uhds or avdi, write full flash and car start....
    FILE SERVICE
  10. The Following User Says Thank You to voltechcar For This Useful Post:
    kvadratas (12th January, 2018)
  11. #10
    Feb 2017
    cmd has a recovery function
  12. #11
    dominik.m's Avatar
    Jun 2009
    POLAND
    Everything ok. But You should do it by OBD2.
