Any help with activation, please.
Version: 14.30.023
Version: 14.30.023
Dwaynej63 (25th February, 2020)
Mr Autokent, the first version I had didn't work. Deleted it and downloaded the link u had in an earlier post. I now have. ID:C0B445DCAD27AAE4BD56AB0ED23F6F00
Version: 15.00.026
Dwaynej63 (26th February, 2020)
Thank you so much. After weeks of struggling, am gonna finally be able to use this, all thanks to you.
ID 6DF25D3931A4EC1E24F80595EE7A800.
V15.00.026.
Please help
Hi Autokent, which version of techstream do you recommend for ecu reflash key programming injectors compensation utilities healthcheck throttle reset etc... Thanks in advance.
Sent from my QMobile L15 using Tapatalk
I will try older version 13. / 14. which came with mvci cable Chinese white one.
Problem is for example if I cleaned electronic throttle of a 2nz-fe rpm goes up at about 1500 rpm and need to reset by removing battery cable..
No additional or advance functions can be found in techstream software which are available in a car. Thanks.
Hi freands
Please help me to activation code
Thank your advance
FD2AD553A932D19ADCFC4DA10E748700
ver : 14.10.028
