Page 13 of 35 FirstFirst ... 38910111213141516171823 ... LastLast
Results 181 to 195 of 515
  1. #181
    Apr 2017
    Any help with activation, please.
    Version: 14.30.023
  2. #182
    Autokent's Avatar
    Mar 2019
    Russia
    Quote Originally Posted by Dwaynej63 View Post
    Version: 14.30.023
    Ver: 14.30.XXX
    NA: a6888899c626ade851199f526a65df3350002002252332
    EU: 4cf2f4bfd10b0926f01a8b72306f8abf50002002252332
    JP: b3a941015bc2230023202500de86e1251cbf4d0b6e00c3
    OT: eec5fea010d99f97265a847f686e395850002002252332
  3. The Following User Says Thank You to Autokent For This Useful Post:
    Dwaynej63 (25th February, 2020)
  4. #183
    Apr 2017
    Mr Autokent, the first version I had didn't work. Deleted it and downloaded the link u had in an earlier post. I now have. ID:C0B445DCAD27AAE4BD56AB0ED23F6F00
    Version: 15.00.026
  5. #184
    Autokent's Avatar
    Mar 2019
    Russia
    Version: 15.00.026
    Ver: 15.00.XXX
    NA: 5d87e1c437dab5064115aa0bdd8f41b550002002261108
    EU: 8c0dbfb29a4a8250f41c9b85206af03550002002261108
    JP: 4c30ac7f95d811002020260008bf5885d8c4045e1d2a13
    OT: 9d8222eecfff6a4baeaaee4cda8aec9f50002002261108
  6. The Following User Says Thank You to Autokent For This Useful Post:
    Dwaynej63 (26th February, 2020)
  7. #185
    Apr 2017
    Thank you so much. After weeks of struggling, am gonna finally be able to use this, all thanks to you.
  8. #186
    Apr 2019
    ID 6DF25D3931A4EC1E24F80595EE7A800.
    V15.00.026.
    Please help
  9. #187
    Autokent's Avatar
    Mar 2019
    Russia
    Quote Originally Posted by rybenz View Post
    V15.00.026.
    Please help
    Incorrect ID length 31
    Need 32
  10. #188
    Apr 2019
    Quote Originally Posted by Autokent View Post
    Need 32
    Sorry you are right, that IDs wrong.
    6DF25D3931A4EC1E24F8A0595EE7A800.
  11. #189
    Oct 2017
    Hi Autokent, which version of techstream do you recommend for ecu reflash key programming injectors compensation utilities healthcheck throttle reset etc... Thanks in advance.
    Sent from my QMobile L15 using Tapatalk
  12. #190
    Autokent's Avatar
    Mar 2019
    Russia
    Ver: 15.00.XXX
    NA: 29f702f8673790819d2a6826408e47db50002003102114
    EU: 89f85bc755484950b36446352bbed98850002003102114
    JP: 31d08a4a0a4e21003120100031739c45b9df5e70fbeb4f
    OT: 97bf4e5c046e6708af1353321da6580650002003102114
  13. #191
    Autokent's Avatar
    Mar 2019
    Russia
    Quote Originally Posted by Butterfly View Post
    Try to use ver.15
  14. #192
    Oct 2017
    Yes I am using this one version you shared but no luck .. Or I should try 13. Or 14. Both came with cable.
  15. #193
    Autokent's Avatar
    Mar 2019
    Russia
    Try any version and maybe you're lucky.
    What exactly is your problem?
    What is your adapter?
  16. #194
    Oct 2017
    I will try older version 13. / 14. which came with mvci cable Chinese white one.
    Problem is for example if I cleaned electronic throttle of a 2nz-fe rpm goes up at about 1500 rpm and need to reset by removing battery cable..
    No additional or advance functions can be found in techstream software which are available in a car. Thanks.
  17. #195
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Hi freands
    Please help me to activation code
    Thank your advance
    FD2AD553A932D19ADCFC4DA10E748700
    ver : 14.10.028
