:-) n75 delete why? u can set to control than u have no max load problem . u must set also maxhfm u need a bigger maf like vr6 70mm .
have u never done this ecu go to a tuner :-) and good luck to find one . this ecu is not easy
Hi. Can anyone look and see if n75 can be deleted, having issues as revlimit is stuck 6000. Doing stage 3 have standalone fuel control, I'm happy so far but to go next step need 7000 rpm and n75 delete. So raise limiter 7000 and n75 delete. if anyone can help that would be brilliant Many thanks.
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
