Results 1 to 15 of 16
    Mar 2016
    Default Problem Nissan Pathfinder Lost key
    Hi guys
    i have problem with nissan pathfinder 2007 lost key
    i prepared a new chip and new key with abrites original and tango original but the problem is the car work but after afew minutes when i try to start the car again doesn’t work at all or when deconect the battery and reconnect it ,so please if you know how to fix the problem help me
    Best regard
    Mar 2016
    I want to know why the immobilizer forget the code pin BCM
    klaudio's Avatar
    Jul 2016
    Quote Originally Posted by samranisimo View Post
    I was doing a nissan almera with id46, same symptoms it will start a few times then after a minute or two nothing until got id60 transponder programmed, worked like a charm. Maybe that's the problem, try and report.
    NISSAN PATHFINDER 1999 2004 Transponder TEXAS Crypto 4D ● ID 4D60 ● JMA : TP19, TPX2
    NISSAN PATHFINDER 2005 Transponder Philips Crypto 2 ● ID46 ● Original key with PCF7946A
    ​Some people just want glory instead of acknowledgment.
    Thanks and reputation is earned, not ask for.
    Have a nice day.
    Mar 2016
    Quote Originally Posted by klaudio View Post
    I used 3 of my chip pcf7936 cause the car model is 2007 . like you said it start a few minute then after i turn the ignition off for some minutes, it the stop working
    i will try another chip and i will reply you
    klaudio's Avatar
    Jul 2016
    Do you have the vin#?
    Have a nice day.
    Mar 2016
    yes i have vin car ....
    klaudio's Avatar
    Jul 2016
    what's the vin#, i'm trying to see if I can identify the transponder type.
    Have a nice day.
    Mar 2016
    VSKJVWR51Z0209873
    Top Poster dooshan's Avatar
    Mar 2012
    Belgrade
    it's 46 allright but...bad module? from my angle,every car that had trouble 'saving' keys tru obd,it was with bad modules...most of them i've managed with bench work.
    so why dont try manualy?
    Mar 2016
    How can i do it manually ?
    Mar 2012
    Belgrade
    can you read it on table and produce image file to write it back?
    Mar 2016
    I read it on table but it work but for a few minute forget the code. And the car doesn’t start
  13. #13
    Mar 2012
    Belgrade
    witch tool do you use for precoding pcf7936? can you post dump maybe?
  14. #14
    Mar 2016
    I use abrites and also use tango
  15. #15
    Mar 2012
    Belgrade
    post dump friend
