boxsport (26th May, 2019)
I am not sure if you figured this out yet.
Did you update the libraries and help folder?
If your car is available in Ksuite, it will also provide pinout diagrams for direct connections or for a positioning frame.
Scroll down that second page with the warnings to get to the instructions before you press OK.
Hello there... I already search and there is no info...
Because this is a Mexican Model, the ECUs are different (at least on the outside).
I already found several post / forums showing the connections for this ecu, but it seems that there are several variants...
Anyway, i already tried reading in bench with several connections, and same result...
I need to open the ECU and see the exact chip on it and sort out how to read this...
But thanks for the comments...
PS.: I found some updated versions of K-Suite 2.47 that i need to test to see if i have better results...
This would be great to see...
I´m not able to find the post i read about upgrading Kess 5.017 to 5.028 by just changing SD card...
I found others, but they are not very specific on that.
I´m staring to think i might have misread the text on my searches, and got confused... You are all probably right by saying the the NXP chip also needs to be changed...
If my comments lead to some confusion here, i need to apologies to you all...
Anyway, i think is a good thing that you all have the will to do some tests on this...
Cheers guys...
NXP, SD card and ftdi chip all got changed on mine
Sent from my SM-G973F using Tapatalk
Sent
5.028, You can send where you bought ?
Pocinas, your inbox is full.
XGamer2019 (20th June, 2019)
Can you send links to me too?
Can you send links to me too? thanks
can you send the link to me ?
You can also contact me for more info, will help and all ready help many to get in business.
