Results 1 to 14 of 14
    Feb 2016
    sveden
    Default nisan primastar ecu problem
    Regards to all.
    I have a problem with a nisan primastar.
    Is anyone able to remove these errors from me?
    p253f
    p1525
    Any help is welcome
    ECU model
    0281016807
    237100718r
    237100832r
    100622 1039s39296
    johak's Avatar
    post file with maps
  3. The Following User Says Thank You to johak For This Useful Post:
    vladoford1 (23rd January, 2018)
    Feb 2016
    sveden
    This is not maps?
    Feb 2016
    sveden
    Default nisan read with galletto
    theare is good now
    johak's Avatar
    if you want, try and report
  7. The Following User Says Thank You to johak For This Useful Post:
  8. #6
    Feb 2016
    sveden
    i can try now
  9. #7
    Feb 2016
    sveden
    look video end 1. dtc code
  10. #8
    Feb 2016
    sveden
    Quote Originally Posted by johak View Post
  11. #9
    johak's Avatar
    with the original has this problem?
    my file may be wrong, but I changed the dtc space
  12. The Following User Says Thank You to johak For This Useful Post:
  13. #10
    Feb 2016
    sveden
    with original vorking fine. only check engine lampa open
  14. #11
    Feb 2016
    sveden
    nobody has to help me
  15. #12
    johak's Avatar
    this should work
  16. The Following User Says Thank You to johak For This Useful Post:
  17. #13
    Feb 2016
    sveden
    i tray leater thanks for your help
  18. #14
    Feb 2016
    sveden
    http://www.cardumps.net/
    look this site is good or not
