write to me in skype
Hi!
I want to tune a car like this. My question is that what is the best/max IQ what engine can handle with good power and not too much smoke?
As I saw in SW the turbo is not ECU controlled like old BMW tds MSA ECUs so didn't found Boost maps.
Found:
DW
TL
Smoke limiter
Injection Pump tension
Should I increase Injection pump map too or max 55mg is enough for good power increasement?
I just ask these things because I never do tune for this engine and I will not use sockets for PLCCs because always have problem with sockets what I can buy in the shop. So I will solder back the new chips on the board and don't want trying about AFR
EDIT:
Ok, I was careless, I found boost and boost limit map. Then, it should be SVBL too somewhere. Can someone help me with address please?
read them !!!
Fec001 (17th January, 2018)
54mg for this car is enough without smoke.
Chiptuning - Diesel / Petrol / Stage1,2,3 / HIGH Petrol Tuning
DSG TUNING
DPF / EGR / TVA / SAI / Lambda
Crackle map ( Launch Control + No lift Shift + Antilag )
File Service
PCMFLASH / BFLASH / AMT BST / AMT MPPS / TGFLASH / BITBOX / EDCSUITEPRO - Genuine USER
Thanks to nikobg and maajkii for infos!
Can someone help with the SVBL please?
Fec001 (19th January, 2018)
