Results 1 to 5 of 5
    Fec001's Avatar
    Default W210 2.9TD MSA25.1 tuning
    Hi!
    I want to tune a car like this. My question is that what is the best/max IQ what engine can handle with good power and not too much smoke?
    As I saw in SW the turbo is not ECU controlled like old BMW tds MSA ECUs so didn't found Boost maps.
    Found:
    DW
    TL
    Smoke limiter
    Injection Pump tension
    Should I increase Injection pump map too or max 55mg is enough for good power increasement?
    I just ask these things because I never do tune for this engine and I will not use sockets for PLCCs because always have problem with sockets what I can buy in the shop. So I will solder back the new chips on the board and don't want trying about AFR
    EDIT:
    Ok, I was careless, I found boost and boost limit map. Then, it should be SVBL too somewhere. Can someone help me with address please?
    Jan 2014
    write to me in skype
    read them !!!
  3. The Following User Says Thank You to nikobg For This Useful Post:
    Fec001 (17th January, 2018)
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    54mg for this car is enough without smoke.
    DSG TUNING
    File Service
  5. The Following User Says Thank You to maajkii For This Useful Post:
  6. #4
    Fec001's Avatar
    Thanks to nikobg and maajkii for infos!
    Can someone help with the SVBL please?
    Dec 2015
    Bulgaria
    Quote Originally Posted by Fec001 View Post
    you do not need it, there will be no problem
  8. The Following User Says Thank You to Rad4 For This Useful Post:
    Fec001 (19th January, 2018)
