Page 270 of 271 FirstFirst ... 170220260265266267268269270271 LastLast
Results 4,036 to 4,050 of 4063
  1. #4036
    Dec 2012
    EU
    Passat back on the road
    Abrites support super quickly send us repaired files.
    Support 5 star on this one.
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
  2. The Following 5 Users Say Thank You to gttuning For This Useful Post:
    alkaskad (14th May, 2024), electromech (21st May, 2024), habbyb (23rd May, 2024), rapidlocksmiths (13th May, 2024), sagie (13th May, 2024)
  3. #4037
    Apr 2016
    Was your cluster completely dead? I have a same case; after modification no signs of life on cluster, connected it on lab power source, it pulls only 0,04 Amps. I was considering getting another one, but I saw your post here and sent support request... I hope I will be lucky sam as you...
  4. #4038
    Dec 2012
    EU
    Default >>>>>NEW AVDI PROBLEMS AND SOLUTIONS ONLY THREAD<<<<<
    Quote Originally Posted by alkaskad View Post
    Yes dead in the car but i still could conect with programer and read mcu.
    Send files to support.
    What i think happens programer read files bad and it cant verify it.
    And when you write back damaged file this is what you get
    Send files to avdi support and they will repair it for you and once you solder to your cluster go striaght to load file. Modify you km and write it back.
    You should be fine then
    I took all safety measures and my experience with this job not to f...up and still issue.
    But i know that this isn't stable read write solution yet. So expect shit to happen. But aslong files can be fixed i dont mind.
    Hope your case can be solved.
    Support done a great job on this case.
  5. The Following User Says Thank You to gttuning For This Useful Post:
    alkaskad (15th May, 2024)
  6. #4039
    Apr 2016
    Quote Originally Posted by gttuning View Post
    They repaired my file and cluster came back to life! I was convinced that I've messed up something physical and was ready to send this one for repair or buy another one... You have no idea how your post saved my ass! Thanks again!
  7. The Following User Says Thank You to alkaskad For This Useful Post:
    gttuning (15th May, 2024)
  8. #4040
    Dec 2012
    EU
    Thats cool. would you mind send me both file original and repaired ? Just want to see if repair file is fixed in same sector as mine.
    My email is
    gttuning@yahoo.com
    Glad you have it fixed.
  9. #4041
    Jan 2016
    Any chance you could find a original 7935 somewhere. I know they are unreasnobly expensive but a single one would do to rule out it being the transponder or the car.
    any idea where i can purchase an original 7935
  10. #4042
    The same here. MQB VDO D70F7526, after writing with Rh850 prog cluster is dead. In this case manage to have backup from different programmer.
  11. #4043
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    Quote Originally Posted by qwojtus View Post
    sounding a very dangerous tool at the moment
  12. #4044
    Dec 2012
    EU
    Jci skoda 2018
    5E0920981F
    D70F3529
    Read write ok.
    Jobe done successfully.
  13. #4045
    Quote Originally Posted by whiskeyman View Post
    For making keys you need to READ data only. Writing is required when replace the dash or just need to change component protection or something else.
    Abrites should fix the issue which defo exists, rather than keep adding $400 licences in beta stage.
  14. The Following 2 Users Say Thank You to qwojtus For This Useful Post:
    habbyb (23rd May, 2024), nenadgorgi (20th May, 2024)
  15. #4046
    Dec 2012
    EU
    These r not that complicated.
    And aslong support can fix the file i dont mind.
    But sure this needs fixing as thisbis not user error.
    Its programer.
  16. #4047
    Jul 2019
    Melbourne, Australia
    V850/RH850 are an erase to read function with all programmers, the chip is erased to remove security, then read and re-written and re-locked during the 'read' procedure. This is why it takes so long. A dead cluster until fixed files are sent are always a possibility if anything at all goes wrong during the erase/read/write cycle. Hopefully one day they will have automated file recovery for us.
  17. The Following 3 Users Say Thank You to Spiritech For This Useful Post:
    habbyb (23rd May, 2024), mbedv (25th May, 2024), u.s (25th May, 2024)
  18. #4048
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by Spiritech View Post
    maybe this is why we are waiting so long for multiprog cable so xhorse can fix bugs
    Solidarity with Ukraine
  19. #4049
    Dec 2012
    EU
    Hello abrites.
    Please repair this.
    Us avdi customers reported this last year if not more.
    Reading immo data tp2.0 micronas it frezz at address seen on screen.
    I have payed for this function so please repair this.
    I have reported this as many other users.
    Hope yous get this that we support avdi to be best tool but you fail to repair this function
  20. The Following 2 Users Say Thank You to gttuning For This Useful Post:
    askkey (25th May, 2024), owdi (2nd June, 2024)
  21. #4050
    Jul 2019
    Hello abrites.
    Please repair this.
    Can confirm. I had the issue on A3 PQ cars for several years now. To be honest, other VAG functions have been acting up quite a bit in the recent couple of years. Especially the functions for older stuff (like windows freezing while reading NEC clusters or unable to read pin on K-line cars) , but usually if a problem arises on Dash immo reading, the function still works on wizard or standard mode or vice versa. But on the 8p Audi, nothing has worked for quite some time.
    I think I have brought it up before some time ago but as usual not progress from AVDI side.
