Page 3 of 271 FirstFirst 123456781353103 ... LastLast
Results 31 to 45 of 4062
  1. #31
    In EEP
    Quote Originally Posted by topclef View Post
    Hello ,
    first car and first failure
    try to add spare key for GOLF7 VDO-MQB 2014 keylessGo , connection to dash ok , connection to server...... , and after few second i get error message ( cannot release SA2 code..... )
    hi you golf is to 6. 2014 this can do only smelecom . For new mqbab model is suport. seedkey and boting procedur was for sell all company bay this keys or scening data from others. therefore they are not older mqb platform.
  2. #32
    Aug 2016
    pass-thru with Toyota tis. i was called out to teach in clutch adaptation after replacement clutch actuator on a Toyota Yaris semi auto. car was accelerating before i attempted to do adaptation. when my adaptation finished . car stopped accelerating. tried many times adapting but wouldn't take it . car was towed to dealers and finally they sorted it with there tool. i believe it was something to do with avdi passthru drivers not right for the job. wouldn't ever use avdi again for Toyota gearbox adaptation.
  3. The Following User Says Thank You to garagetech007 For This Useful Post:
    nenadgorgi (22nd January, 2018)
  4. #33
    Aug 2015
    Made today w246 key with a working key it found pass under 10 min.
    This time i must not make the esl virgin.
    Is it not now no more neccessary to make the ESL virgin?
  5. #34
    Top Poster dooshan's Avatar
    Mar 2012
    Belgrade
    Still is...
  6. #35
    M3L3R's Avatar
    Mar 2014
    Kolobrzeg
    I have problem with ZN002 PROTAG. Doesnt want to read/write ID48, pcf7936 and probably more. My reseller told me that its normal; protag is very unstable and I have to wait for updates. Is it true?
  7. The Following User Says Thank You to M3L3R For This Useful Post:
  8. #36
    Gavra's Avatar
    Belgrade/Melbourne
    Quote Originally Posted by offsystem View Post
    ESL virgin is required only all key lost situation and not with all models. I do not understand any of you complaining about that. I have 2 boards virgin which I use just for that.....
    Bigger concern is when will January update link show up in email?
    Guided fault finding = Feature that many factory scan-tools have and real technician despise it.
  9. The Following User Says Thank You to Gavra For This Useful Post:
    dooshan (23rd January, 2018)
  10. #37
    Fallen's Avatar
    So did the new Abritus representative last less than 3 days in this new thread?
    WTF did they go?
  11. #38
    Mar 2012
    Belgrade
    Quote Originally Posted by Gavra View Post
    I must say,W169 add key situation,sw did ask for ESL virgin state..didn’t have at the moment virgin board,so I’ve read EIS on bench. Will have it in my case in future
  12. #39
    Mar 2012
    Belgrade
    Quote Originally Posted by M3L3R View Post
    Didn’t have this issue... I did use it few days ago just for that,writing 7936. Reading other transponders also worked. Preparing too.
  13. #40
    topclef's Avatar
    we post what does not work and what works
    I just add spare key for Seat Leon 2015 , and the remote control work well
    you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
  14. The Following 3 Users Say Thank You to topclef For This Useful Post:
    clearly (29th January, 2018), doctore (23rd January, 2018), Fallen (23rd January, 2018)
  15. #41
    Feb 2017
    Quote Originally Posted by Fallen View Post
    It would be good if we could have a function to check internet connection once a commander is loaded up.
    For example, I have to often open AVDI software twice before it will connect with the server.
    This becomes an issue when you read MED17 ECU data for example, then it try's to upload data and you get failed internet connection wasting time.
    In such cases I would suggest to open the BMW2 software first (or another cloud based software). If there is no connection you won't be able to proceed selecting the model.
  16. The Following 2 Users Say Thank You to ventzy For This Useful Post:
    Fallen (24th January, 2018), rapidlocksmiths (23rd January, 2018)
  17. #42
    Feb 2017
    Quote Originally Posted by whiskeyman View Post
    Ok so this my fails this week with avdi
    Passat b4 2004
    avdi freeze screen when try read pin
    kia ceed diesel yesterday
    2012 try to read pin for spare
    failed
    will list as I go this week
    Regarding the Passat - please check the connection between AVDI <-> OBDII. This is most common reason for this behavior of the software. It happened to me yesterday with an Audi A4 B6.
    Regarding the Kia Ceed - according to me the model is not supported as our coverage is at the moment limited talking about models after 2012/2013, we are aware of that and currently working hard on it. We just updated our PassThru driver for some OEM software as Kia GDS 2017 and Huyndai GDS 2017. Next step would be to update the coverage of the models.
  18. The Following 2 Users Say Thank You to ventzy For This Useful Post:
    rapidlocksmiths (23rd January, 2018), whiskeyman (24th January, 2018)
  19. #43
    Feb 2017
    When using VW software and you find 6 bytes from the ECU and 7th byte for a working key, it would be nice if you could just press program and it will write all the bytes to the transponder.
    At the moment, once you have found the 7th byte, you then have to manually select "all 7 bytes known" and then manually transcribe all the bytes into this field.
    It's a painful process and if you get 1 of the 14 digits incorrect, its all over.
    We have two different processes which is resulting in this inconvenience:
    1. To prepare the key - for this purpose we need to find the 7th byte
    2. To learn the key - unfortunately this process is not directly connected to #1, and the key learning process will not try to find the 7th byte but ask you to insert all 7 bytes manually.
  20. The Following User Says Thank You to ventzy For This Useful Post:
    gttuning (23rd January, 2018)
  21. #44
    Feb 2017
    Quote Originally Posted by schouten1977 View Post
    golf 7 2013 not possiblle to change mileage
    It is not possible because we do currently support VDO/Continental dashboards 2014+ only.
  22. #45
    Feb 2017
    Quote Originally Posted by wissamshaat View Post
    only problem for me is the price
    any solution for that ???
    Yes, you are free to buy any product on the market which meets your needs.
  23. The Following 2 Users Say Thank You to ventzy For This Useful Post:
    clearly (29th January, 2018), rapidlocksmiths (23rd January, 2018)
