rapidlocksmiths (25th January, 2018), topclef (25th January, 2018)
ventzy : Please fix the problem on Micronas dash when updated immo data, reset button is missing.
Send mail to support, they said dash will reset automatically, but seems not (tested today on 2 cars).
Bring back reset buton.
Also can you bring back button to load service mode on NEC c32 c64 dash dump. It wants to be plugged in to dash 1st which makes it longer
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
wiseman (26th January, 2018)
gttuning (26th January, 2018), lupu_sandu (27th January, 2018), rapidlocksmiths (26th January, 2018), z786 (28th January, 2018)
Just press "Enter Service mode by OBDII" . If it is not possible (e.g. you don't have a working key) the software will display the following message:
"Cannot connect to the immobilizer.
You need to modify the do ConfData of the dashboard with a programmer.
Please load the ConfData dump of the dashboard read with a programmer.
Do you want to continue?
YES NO "
If you don't have a working key it might be required to read it on bench. I think if it is VDO you will be always able to do it via OBDII.
You could also use VN006 for key programming via OBDII(for Immo 3/4 systems and Megamos 48 transponder with or without a working key).
Hope this info helps.
Today after reseting some used opel astra H keys with protag i recive message FORBIDDEN ..! Now i am trying to reset some more but allways message FORBIDDEN
Did anyone else noticed the Toyota 11.3 update on the site? It had a lot more features before. They removed most of the features and just left a few that most other machines can do already..
ventzy
you are wrong about vag nec
the process looks now like
you HAVE to be connected to the car to press enter service mode by obd.
without working key it will ask you to read conf data etc we all know the process
if you press enter service mode without connecting avdi to the car it will tell you you can not communicate with immo and you have NO way of loading conf data dump - there is no button as it used to be
if the procedure is corrupted by anything you need to solder eeprom back to the speedo, fit it to the car, start procedure again by pressing "enter service mode by obd" to get message about loading conf data dump
if "cant connect to immobiliser" info you CAN NOT load conf data
we would like it to be as it used to be OR
as you say - if "cant connect to immobiliser" message is displayed, the button to load 24c32/64 dump button
please check photo attached
Completely true , it work like ventzy said
I did a GOLF6 2012 , all keys lost VDO-NEC .
I have modified the dump without connecting to the car , and all procedure is the same as old .
now , we have only 1 button , these photos can resumed the whole procedure in the lost all key situation .
finished by puting the dash in the car , enter service mode ok , AVDI ask you if you want to write the original dump , i click yes , writing is done , read immodata, erase all key and make new keys .
you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
Today component protection Audi A4 2009.. SRS unit.
All ok is just i couldn't read gateway by obd ..had to read with programer...
Sent from my SM-G935F using Tapatalk
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
