Page 1 of 271 1234561151101 ... LastLast
Results 1 to 15 of 4065
    Moderator
    PremierD's Avatar
    Jun 2009
    Default >>>>>NEW AVDI PROBLEMS AND SOLUTIONS ONLY THREAD<<<<<
    LET'S GIVE THIS ONE MORE TRY ....
    So this is how it will work ..
    Post a problem one at a time, specifics of that problem (no cheats liars fannys or fuds.) in the decription.. then we wait till we get a reasonable reply or in fact, a solution to that particular problem .
    If it gets out of hand then we will not have a thread at all (which may suit Arbrites) but who knows, maybe they are not as full of shit as has been suggeted
  2. The Following 27 Users Say Thank You to PremierD For This Useful Post:
    abdelamjid (11th March, 2018), CaioW (17th January, 2018), daxxer (17th January, 2018), doctore (17th January, 2018), dooshan (17th January, 2018), ecuhamed (25th May, 2022), Fallen (17th January, 2018), gttuning (17th January, 2018), hass42 (20th April, 2018), i-vtec (17th January, 2018), isma123 (20th January, 2018), Johnner (19th January, 2018), luiyitox (26th November, 2019), Mario3 (20th January, 2018), norman1967 (23rd January, 2018), offsystem (17th January, 2018), p1et (17th January, 2018), pepi (17th January, 2018), phananhtu (7th May, 2023), rapidlocksmiths (17th January, 2018), skinsh (10th December, 2023), smokey08 (17th January, 2018), super jumbe (21st January, 2018), tizi94 (17th February, 2020), topclef (17th January, 2018), ttzag (21st January, 2018), zlatinou (18th January, 2018)
  3. #2
    OK. Lets try...
    FIRST PROBLEM.
    AVDI compatibile with Tech2 - not working SPS from GlobalTIS - when i start SPS - proces don't start but my hard drive starts to fully, on disk is written log files which grows... some update before this function works OK.
  4. The Following 5 Users Say Thank You to i-vtec For This Useful Post:
    doctore (17th January, 2018), luiyitox (26th November, 2019), PremierD (17th January, 2018), ps80l (19th January, 2018), tizi94 (17th February, 2020)
  5. #3
    WHat global tis you use?
    I use it with V32 and work normal.
    You have comunication with car when open Tech2WIn?
  6. The Following 3 Users Say Thank You to wintesla For This Useful Post:
    pepi (17th January, 2018), PremierD (17th January, 2018), tizi94 (17th February, 2020)
  7. #4
    Yes i have comm. and also use v32. This is very strange because if i select on device list a real Tech2 (i have original) sps starts normal, when i select AVDI it's detect VIN and software version in ecu but when shows % is always 0 and my hard drive starts to fully, on disk is written log files which grow (as i say before).
    My friends also report when use online version TIS also not compatybile anymore.
    I think about 2 years was good and works very well - now i and few of my friens have this problem but i'm not 100% sure is this isue is of all ecu types.
    NEXT PROBLEM.
    In Opel software from about 3 years in Astra J with EDC17 i's impossible to erese errors - i test it on few of astra j and never worked erase errors. If i use avdi as mdi i can read and erase errors in this car - so i think this is only a software bug in opel software.
  8. #5
    This is strange
    when not have comunication with car trouh Tech2Win then is problem like you describe.
    I use Globaltis minimum one time on day and not have problem.
    Next question
    Global Tis 32 what version? My is 32B.
    What windows use or is instaled on VM? I install on VM
    with WIN7 32bit , Explorer 8 and Java ( i not remember version ,i can chek and write you)
    What device chose from list when go to sps
    Abrites or mdi?
    For SPS have note from GM to use Tech2 on every car where you can ( on older car).
    Sometime have problem with Mdi, and some time.have problem with avdi ( when finish reprograming start again to reflash.So must manualy turn key to stop when programing is finished and you get chek light on dash)
    This is only problem what i know and what i have from time to time.
    About Astra J - open avdi sw conect to car with edc17
    read and write error .Close and send log file to your dealer.If you not.get answer from your dealer in 2 working day, send me log file.
  9. The Following User Says Thank You to wintesla For This Useful Post:
    rapidlocksmiths (18th January, 2018)
  10. #6
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    Ok so this my fails this week with avdi
    Passat b4 2004
    avdi freeze screen when try read pin
    kia ceed diesel yesterday
    2012 try to read pin for spare
    failed
    will list as I go this week
  11. The Following User Says Thank You to whiskeyman For This Useful Post:
    doctore (19th January, 2018)
  12. #7
    obdsystems's Avatar
    Oct 2013
    U.K, not the E.U.
    Quote Originally Posted by i-vtec View Post
    OK. Lets try...
    FIRST PROBLEM.
    I did have it running but to tell truth, but rather not use AVDI as pass-thru
    so many cheap ones off ebay -tend to use em instead
    I am a FUD
  13. The Following User Says Thank You to obdsystems For This Useful Post:
    isma123 (27th May, 2018)
  14. #8
    whiskeyman's Avatar
    Dec 2010
    xxxxxxxxxxxxxxxxxxxx
  15. #9
    Mar 2017
    GM global connect website always fails when I do SPS...starts fine but seems to slow down and does not finish. Always end up using dedicated J2534 adapter.
  16. #10
    Fallen's Avatar
    It would be good if we could have a function to check internet connection once a commander is loaded up.
    For example, I have to often open AVDI software twice before it will connect with the server.
    This becomes an issue when you read MED17 ECU data for example, then it try's to upload data and you get failed internet connection wasting time.
  17. #11
    Fallen's Avatar
    When using VW software and you find 6 bytes from the ECU and 7th byte for a working key, it would be nice if you could just press program and it will write all the bytes to the transponder.
    At the moment, once you have found the 7th byte, you then have to manually select "all 7 bytes known" and then manually transcribe all the bytes into this field.
    It's a painful process and if you get 1 of the 14 digits incorrect, its all over.
  18. #12
    wissamshaat's Avatar
    Oct 2017
    france
    only problem for me is the price
    any solution for that ???
  19. The Following User Says Thank You to wissamshaat For This Useful Post:
    ecufix (14th April, 2019)
  20. #13
    Apr 2016
    holland
    golf 7 2013 not possiblle to change mileage
  21. #14
    koln, germany
    sorry for your golf 7
    MAYBE THE OLD tread should be reoppened ,?
  22. #15
    Fallen's Avatar
    Quote Originally Posted by schouten1977 View Post
    Golf 7 only from 07/2014
