BADBOYS_FOREVER (28th February, 2020), habbyb (21st February, 2020), whiskeyman (26th February, 2020)
So it was vdo nec..
Use zn059 to put to service mode..
Avdi ask to put new AES key to protag .
Transponder write successfully..and you see on dash 2-3..
Read immo again but still no key on position 3..
So plug dash back to van and you can see its writing key in 3-3..
Then read immo data and key is stored in position 3....
All works ok..
Sent from my SM-G955F using Tapatalk
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
Is VC vw already supported to add keys?
What happens with the new component protection feature which was announced???
is not mqb vdo with nec only with aes cip key and yes suport add keys
someone has done coding on frm after repair bmw , thanks
Yes you can do coding of FRM.
Sent from my SM-G975F using Tapatalk
habbyb (24th February, 2020)
If it was working before but not now contract support
all VAG with 1.6 TDI PCR2.1 , you have to unlock ECU to extract pin and CS.
you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
on PCR2.1 ECUS you need unlock ecu on bench,,put it back to car and read cs pin..
precode key
then program new key..
KILL_THE_IMMO (2nd March, 2020)
correct...........
