w447 vito is fbs4 and key programming isnt covered by any aftermarket programmer at present , pointless abrites listing it if like all other aftermarket tools its not covered yet
All manufacturers are weak on Mercedes -wonder if we will ever see new coverage or is FSB3 finial
Solidarity with Ukraine
Tried to read pin code on a 2006 Corsa C, it reads and gets comms, but no pin code gets displayed, tried few times, and after 15 seconds it displayed the pin code, this is after the recent update
what engine code was it ? as some can be a pain and avdi one of only tools that gets some of them .
alot of these have various faults , possibly failed to read from screen so went to ecu which may account for the 15 second wait ?
ive used avdi on quite a few vauxhall models since last update and not had an issue , not done a corsa c since last update though.
Hi mate, not sure about engine code, it was 1600cc. i know what you are saying but usually when the bar reaches %100 it immediately shows the pin, but this time took around 10-20 second to display it(there were no indication on the software that it was doing something), i tried to pull pin via the cluster and Z16XX engine code, before the software purchase/update it was ok.
ps. forgot to use the legacy mode.
probably failed on first place it looked then tried elsewhere , no problem in end as you got code , i tend to use legacy mode on the older stuff
since last update ive done an astra G and a tigra ( same system as corsa c but different engine ecu ) thats all on older stuff rest have been astra H , J and k , insignia mokka , corsa D and E, no c , but had no issues to date
I have a 2014 Insignia 3 button, and Astra H 2010 lost key comming next week, will update the post
just done another astra K , no issues at all on this , did 2 x insignia over weekend an 11 and 14 plate no issues , did a zafiera B today no issues , you should be fine mate , i last updated last week after the purchase of some new licences , but have done plenty of vauxhalls too since last general update last month
Thanks for the feed back Martin.
2020 Citroen Dispacth AKL, AVDI failed writing flash while trying to find pincode using online software, now i have a blank dash and no ignition lights!
need help/ advise please, last job today before leaving for a holiday tomorrow and off course this would happen.
where can i get back up file ? and how can i write it?
i don't have AVDI support!
as whiskyman says check your log files , shame you dont have support as they would try to sort it on teamviewer for you.
if the log file has corrupted flash it will tell you the correct flash needed so you can obtain a clean flash file , had you had avdi support they would send you one , as not then if you list the correct flash file needed someone may have one to send you
