pepi (9th April, 2018)
Defo not working atm. Did the job Sat...
was there for 3 hours.
Went back today after disconnecting battery last night, in the hope it may reset, no joy another hour at car trying different things.
Really hoping mechanical key trick will work. No idea which way to turn if it doesn’t.
Any way to generate key from supervag bin file?
Hi all.
Have a mini here with secondhand ecu...
Edc17c41
How can this be done with abrites.?.
I havent got the ori ecu.
So i have to readi ISN from ecu.is this by boot mode? Or can be done by obd.?
Thanks.
Sent from my SM-G935F using Tapatalk
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
Ok so i got that ecu programed...it was edc17c50 not c41
First conet engine ecu in boot mode.
Read password.next read dflash.when finish reading dflash press edit you will have isn from ecu.
Fit ecu back tp the car and writ that isn to cas3 by obd..
Car will start.
I also try to write Cas3 isn to ecu but car wont start that way.is that normal or software issue in abrites?
norman1967 (15th April, 2018)
Some pic.
ps80l (11th April, 2018)
guys is VAG golf 2.0tdi ppd1.2 supported for pin cs by obd?
i try it but wont work.
I guess Ventzy gave up...
