Page 72 of 268 FirstFirst ... 2262676869707172737475767782122172 ... LastLast
Results 1,066 to 1,080 of 4016
  1. #1066
    Jul 2019
    Quote Originally Posted by gttuning View Post
    What ecu...
    Sent from my SM-G955F using Tapatalk
    Sorry, EDC17/MED17 Boot mode old VN004, now EP001.
    Looks like last update was disaster
  2. The Following User Says Thank You to immoneard For This Useful Post:
    yugo45 (4th August, 2019)
  3. #1067
    Oct 2018
    Hi guys, does anyone familiar with the Subaru key special function? I just got the special function, add key is working fine, car start but the remote not working, i check in the integ. Unit Mode but there is no function to program remote, car is 2012 impreza with 4D82 transponder. Did i miss something or this avdi really can not do the remote 20190714_113804.jpg
  4. #1068
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Avdi not program remotes
    Renault ECU tool / IO terminal / A.S.W
  5. The Following User Says Thank You to drugowaz For This Useful Post:
    lazymechanic (15th July, 2019)
  6. #1069
    Apr 2014
    What is the feedback on the success rate of Porsche ecu adaptation with module P0009?
    Sent from my SM-G930F using Tapatalk
  7. #1070
    Jul 2019
    Quote Originally Posted by immoneard View Post
    Anyone has problem with Immo off for VAG ???
    ANYONE????
  8. #1071
    Oct 2018
    Hi guys, i try to make key and remote for the 2004 Grand Cherokee today with abrites using the J1850 adapter but can not read pin code, keep asking to put blank key in and then it fail, should it read pin code first then make key? but look like it try to make key first then read pin code
  9. #1072
    fred77's Avatar
    Jun 2019
    Today Bricked C4 Grand Picasso '16 - after years of faultless pin extraction
    Possible software bug - after erasing flash displayed failed message with no log file.
    Be warned
  10. The Following 3 Users Say Thank You to fred77 For This Useful Post:
    Fallen (20th July, 2019), nazz2 (22nd July, 2019), yugo45 (20th July, 2019)
  11. #1073
    Apr 2014
    Quote Originally Posted by trinicolin View Post
    Went ahead and took the plunge. Was able to successfully clone Porsche Cayenne 2011 ECU. EDC17CP44. Impressive I must say.
  12. The Following User Says Thank You to trinicolin For This Useful Post:
  13. #1074
    Jan 2017
    Netherlands
    Fred
    What do you mean, you erased flash? May I ask why not read pin and just program new remote? Or was system bricked after 'read pin ' function (not with dumps etc.) --- I agree with you that even with extraction of flash / dump it would be a disastrous error if the ecu flash would be gone. Did you send a report to Abrites? Though I have some bad experience with serious problems (once software messed up a odometer in a Movano, they just ignored the mails when it became clear the solution wasn't a simple one).
  14. #1075
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    most of the new pug/citroen is going to be read and write flash
    and if you expect a solution from abrities for a fix forget it
    they buy in there softwares from other developers
    have done for years now
    am just waiting for the next cut away update
    see whats missing next...………...
  15. #1076
    Dec 2012
    EU
    Beetle 2015 still megamos id48 lost key...
    Read immo data CAN cluster...
    Try add key some error" ID1 length error...
    Wont add key...but it makes dealer key..
    I use standard key learning...it ask for pi and cs ...type in ..ignition on/off...
    Car starts...all ok..
    Read immo data but no key data..car runs ok..
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
  16. The Following User Says Thank You to gttuning For This Useful Post:
    yugo45 (22nd July, 2019)
  17. #1077
    They a FuC KEED MADNES IDIOT, new function for PSA PN017 cost 1380 euro, PN018 also cost 1380 euro, if someone have PN016 update to PN018 cost 380 euro, update from PN015 to PN017 also cost 380 euro, BUT BEFORE THEY RELESE THIS FUNCTION PN015 cost 1600 euro and PN016 also cost 1600 so they lowered price for new user and ROBBER/CHEAT/THIEFT old clients - they lowers the value of PSA software at the same time they demand from the OLD users of next considerable money! What The Fu_ck?
    SO FU_CK ABRISHIT COMPANY!
    BTW. kia is big shit, tag prog can't even clone Megamos48 and ID33, K-Line in VAG DON't EXIST anymore!
  18. The Following User Says Thank You to i-vtec For This Useful Post:
  19. #1078
    whiskeyman's Avatar
    Dec 2010
    Quote Originally Posted by i-vtec View Post
    100% agree mate
  20. The Following User Says Thank You to whiskeyman For This Useful Post:
    nenadgorgi (21st July, 2019)
  21. #1079
    Aug 2009
    Hampshire
    Time to buy more toys,comparing smok to Io terminal at the moment, difficult to decide which bsi/ecu of them 2 tools to buy.
  22. #1080
    Jul 2019
    Same thing with VN004 it was 1000 euros, Now new function is EP001 and it is 500 euros with more functions and more ECU to read for all manufacturing .
