Was workingn on few bmw over the past few days...so i usually be testing avdi..
Any bmw F series i do integration level update it brakes the car ..failed last week on f07 GT to program footwell...fails to put module in to bootloader.. Autel failed aswell ..Autologic done it without problems..
Always have to use Autel to fix the integration level update..
Any had luck with update integration level on F Series?
Sent from my SM-G955F using Tapatalk
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
habbyb (2nd July, 2020)
So today...2019 508 Delphi bsi...
Unsupported version..
Contacted support they organized TV with developers...1:30 hour ..BSI version added to PSA online version
All works ok
Toyota Prius 2018 (January) akl. Can I do it with avdi?
Thank you in advance
BMW 5 F10 2011 gearbox 8HP reset and program under 15min with abrites online bmw !! congratulations ; - ))))
fred77 (11th July, 2020), habbyb (12th July, 2020), whiskeyman (11th July, 2020)
wish they would sort out ford
menu shit for key programming and lot of fails
they r on fb again saying Ford fixed. i made a fair comment of criticism.
doesn't bother me i buy modules i need n those i don't. time will tell abrites r no different 2 others but maybe charge little more
for all the criticism i still recommend them - and have done jobs others haven't .
Put it this way .... DK don't criticise Fly users - yet copied shite
rapidlocksmiths (14th July, 2020)
have to agree , its not perfect , far from it , but id sooner have it than not have it , and it pays its way and some .
DK criticises all manufactures who rip punters off mate .............................
whiskeyman (14th July, 2020)
thats almost every manufacturer in this game then, alot have had their moments some worse than others .
yes dk does take manufacturers to task and often rightly so and im sure has had some positive influence on some , but many do so for their amusement too which is not so useful , some abrites functions are not good but some are excellent as is the same with im608 , smart pro etc etc , though you rarely read about the good but always read about the negatives .
fred77 (18th July, 2020)
2017 transit ..tryed milage ..still wont change
I should criticise Autohex. Cost me a fortune yet can't do a spare key for a 5 series (unless i remove engine ecu off!!)
I should criticise IM608. It's not top programmer and has failed to do an old 15 year old mini.
Actually come to expect no tool does everything. Pleased with both and use AVDI every day.
