Results 1 to 8 of 8
Hybrid View
    Sep 2015
    Earth
    Default problem with bsi of c3
    Hello, I have a problem with a BSI of a citroen c3 1.4 hdi ref : F02.00 9646775180. the old bsi is oxidized but the car start and stop normaly but there are some options that do not work, I took exactly the same bsi, I virginized, recode with lexia exactly like the old. but what happens is that when I take the ignition off the dash stays on and the car does not stop. have you ever had the same problem. I tried several bsi but still negative BEST REGARDS
    bmw for ever
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    bad configuration, or electrical damage in donor bsi
    My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
    My help not for free, press THANKS and REP, for make me HAPPY
    im not using passwords, my work is for this forum and members free
  3. The Following User Says Thank You to Pyromaniak For This Useful Post:
    Masterprog (22nd January, 2018)
    Sep 2015
    Earth
    no i try 3 other bsi today and same problem, the old work good but the new no
    bmw for ever
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    you make virgin, try copy old bsi data to new, no make virgin. (i think must be data, if make on three bsi same problem)
    Have you right bsi? (hw sw)
  6. #5
    Sep 2015
    Earth
    hello i do it but that not change
    bmw for ever
  7. #6
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Try communicating with lexia to see when you close the ignition,does it read closed switch??
  8. #7
    Check you have correct bsi. Try and match numbers up. Normally this fault is with under bonnet fuse box when ignition will not turn off.
  9. The Following User Says Thank You to radiosolutions For This Useful Post:
    Stelaras26 (30th January, 2018)
  10. #8
    Sep 2010
    europe
    Try to hold brake pedal and the same time put the igniton off.
    Is the motor stops ?
