Results 1 to 2 of 2
    Feb 2016
    Default Audi A5 Steering Assist 44 errors demaged
    I have a problem with the 44 Steering Assist of the Audi A5 2013
    I have 3 errors:
    6291727 - Internal Control Module Memory Check Sum Error
    B2000 00 [137] - Reserved by ISO 15031-6:2005
    1052420 - Internal Control Module Memory Check Sum Error
    B2000 49 [137] - Internal electronic failure
    1052432 - Internal Control Module Memory Check Sum Error
    can you use the flash option with ODIS-E or VCP?
    Feb 2017
    england
    most likely the clock spring behind the steering wheel check the link this is what it looks like iv replace three for the same codes.. do some more checks and if you do replace it save the coding using vag com or vas from the original part and use the coding to code the new part .
    https://www.ebay.co.uk/itm/Airbag-Cl...kAAOSwB09YOUVa
