Results 1 to 8 of 8
    irfa's Avatar
    Feb 2016
    Default VW Visteon rcd320, how to reset
    hello frıends
    I have my rcd 320 radio,
    radıo blocked always safe 2, how do I reset it, I know the code
    best regards
    Oct 2013
    Ukraine
    Hi.
    uPD70F3634 (QFP64) or D70F3635A (QFP144)
    or If the display continually shows "SAFE 2" then the unit may be codelocked and will need to be left switched on up for up to two hours to reset before another code entry attempt is possible.
  3. The Following User Says Thank You to masterskay62 For This Useful Post:
    irfa (25th January, 2018)
    Jun 2017
    Italy now...
    Put radio on the car.....after you can enter code..same RCD215
  5. The Following User Says Thank You to Juliano31 For This Useful Post:
  6. #4
    irfa's Avatar
    Feb 2016
    Quote Originally Posted by masterskay62 View Post
    Hi.
    mate no car, I'm testing at the desk, the radio is off after 30 minutes, other solution
    Argentina
    Put radio on the car.. only work
  8. The Following User Says Thank You to juisro For This Useful Post:
  9. #6
    I have the same problem with two radios this from months to
    Even if you leave an hour on with the key in the ignition the radio switches off and SAFE2 continues
    So far I have not found any solution to reset SAFE2 of this model VISTEON
  10. #7
    Argentina
    Hello, I solved it with the original vehicle, with the passenger door open and igniting the stereo or with the 2 doors open and the same process and enabled the stereo without asking for the code. I hope it could be useful.
  11. #8
    Jan 2021
    Has anyone been able to solve the safe 2 unlocking, without the original car?
