semsem
[ECU]
VIN="WVWZZZ3CZ8P124534"
IMMO ID="VWZCZ000000000"
CS="83 87 9C 93 07 0F 00"
MAC="EF 1A 3A 81"
Config="37 E5 54"
PIN="31525"
Immo Type="IMMO 4"
Immo Status="Learned"
thnx button and repultation........pass send pm
semsem
[ECU]
MAC="EF 1A 3A 81"
Config="37 E5 54"
PIN="31525"
Immo Type="IMMO 4"
semsem (1st April, 2020)
CAN YOU SEND PASS
this alone is real immo off solucia and safe
HOW CAN CLEAR DTC FROM MY FILE ?
the only solution in the world to buy ECUDecoder and delete Uxxxx errors with it,sofware cost 1500e+year update 300e
- Option : Added UXXXX code easy removing. Please just type numbers only after U char.
THANKS I WILL TRY AND REPORT
Why don't you just clone and adapt?
BECAUSE ECU IS BASSAT AND CAR IS JETTA IT LIGHT EPC LAMP
First stop writing in upper case, then read again what I wrote.
FILE NOT OK CAR START ONE TIME IF I CLOSED SWITCH AND OPEN NOT START MUST CLOSE AND OPEN SWITCH TO START
ANY HELP PLEASE
test it and report
thanks file is ok
semsem
The following errors occurred with your submission
- semsem has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
unfortunately the code in dtc code can not help i have no software for it, i send you the only software in the world that can in dtc code to shut down.
why couldn't you write immo off flash ??? was it good my solution immo off ??
semsem (2nd April, 2020)
