I rewrite without error
Hi tewodroski,
as i said to you in my first message I suppose you have a problem with the engine ecm.
I will make some questions and I will give you the answer that I suppose:
1) when you connect the et, how many ecm do you find? I suppose "just one", but you must find two ecm.
2) The engine cranck but doesn't start? I suppose "yes"
If my answer are correct your engine ecm is dead, part number is 2129450 and to change the ecm you must reflash the ecm with the correct flash file, you must enter the trim code of injector and you must do the timing calibration (theese works are not easy to do)
To make sure that your ecm is dead you must check if you have, with key switch on, 24v on pin 6 wire 308 yellow, and you must have ground on the pin 5 wire 200 black, if you have ground and you have 24v change the ecm!
I hope to be wrong but................
