Thanks i hope to play with file
the clip when I run my application Insert clip launcher x 91.exe has encountered a problem
hi patrian
do you know were i can find the spx removal tool for the clip program, cannot locate it.
To avoid PERMANENTLY this SHIT do the following steps:
1) Alt+Ctrl+Del (Kill process RSRWin.exe)
2) Delete RSRWin.exe (in C:\Windows)
3) Use Regedit (and Delete "ALL" values with name RSRWin)
4) Reboot your machine!!!
5) NO MORE flash for SPX Registration...
Taken from Patrian post here :
http://www.digital-kaos.co.uk/forums...n-98-a-102749/
regards.
Just start, and all come itself!!!!!!!
martinracing (20th October, 2013), pekelan (17th April, 2021)
Thanks a Lot. I have a genuine clip. I ask with v97 it is possible to code keys?
you can program keys only if you have access to renault.net
the clip prog ask you a security code
What is it in the reg file thats edited ?
Hi, I'm new around here buy renault clip machine, will not let me install it because I have no JCAECI.sys file, I can not find on any side, even though I look not on the cd or anything.
I see that you have to lick to download that file as the drivers but will not let me.
someone would be so kind that I might send files by e-mail
thank you very much
Hello
i have problem with install renault clip, abort process in 69 % why?
I read instructions, i install crack
Whats the problem?
