Results 1 to 3 of 3
    Jun 2017
    Default What hardware + software to virginize modules like: BCM/BSI + TCU/TCM + CEM + SRS/SSR
    Have a couple of questions guys:
    1. What tool/tools(for read and write) and what software(to edit dump) would you recommend to support - if you need to work with a wide range of modules in many different carbrands that are often 1-5 years old, so its also quite new cars?
    (example of modules that i often work with= airbag, ecu/ecm, tcu/tcm, bcu/bcm/bsi, cem, bmw lcm/ews/cas/dme, mb eis/esl/etc/ecu) ?
    2. What version or even better - Where - do you buy your FVDI from with hw/fw/sw that works well(is stable)? And what version(for example; FVDI 2017..) do they have/do you recommend? The newer, the better... Need support for quite new cars 1-5 year
    3. What tools and software do you use / recomend for obd key cloning / coding keys etc.
    4. What software that support many brands and moduletypes do you use / recommend that virginize the module dump for you?
    Thanks for your time :-)
    Jun 2017
    Anyone care to share?
    Jun 2017
