Results 1 to 5 of 5
    Feb 2013
    Default Nissan NV200 SID307 DTC removal
    could someone remove DTC P0544 - only engine light on, no limp mode.
    Car is Nissan NV200 2014 SID307.
    Thank you
    johak's Avatar
    here you go
  3. The Following User Says Thank You to johak For This Useful Post:
    kvadratas (30th January, 2018)
    Dec 2013
    Quote Originally Posted by kvadratas View Post
    Thank you
    Here it is the file
    DPF/FAP off, AdBlue off, EGR off, Throttle valve off, Flaps off, DTCs off, Lambda off,
    Feb 2013
    Johak,
    thank you very much, works
    Jan 2016
    i have a problem on nissan nv 200 P2002 paritcle filter
    can you do a dpf off for this car
