I don't trust kess anymore , if you have k tag make this job with ktag bdm , till now Ktag make no problem!
Trimis de pe al meu SM-G930F folosind Tapatalk
strange case on Vw Golf 6 1.6 pcr 2.1. With Kess v2 a bench Unlock ecu and ok, I start the machine and perfect. Then I go to read the ecu when I do ID tells me "ecu non recognized" if then I read the reading gives me the same message then I continue and read the ecuand in ID message VIn, motor ,and "UNLOCK". It could give an error because the ecu has been updated in VW for the diesel gate. Can I dare to write or do damage? Help Me please.
Ecu write all ok, car start ok .thank you
Inviato dal mio LENNY3 utilizzando Tapatalk
for now genuine kess do it this ecy by obd, no need unlock and open ecu.
FILE SERVICE
cmd good tool but check prices new protocol, New F-serie by obd, strange price..... Other tool have new protocol with your subscription price.
FILE SERVICE
CMD and X17 works perfect with PCR. CMD is faster than x17. With New Genius I didn't try yet.
I had same situation, after update VW, ecu is locked again, you need unlock it. I do it with K-tag and kess say's UNLOCKED. But after read/write over obd car car doesn't start.
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
