Results 1 to 13 of 13
    Aug 2016
    EURO-KOLCHOZ
    Default CORSA 1.3 Cdti 95PS EDC17C18 NEED HELP WITH DPF OFF
    Hello Masters, need help with dpf off on ecu edc17c18 from corsa D 1.3 cdti,intresting only proven sollution.
    thanx..
    Dec 2012
    dpf off Your file
  3. The Following 2 Users Say Thank You to tugishrugish For This Useful Post:
    jetronic30 (1st February, 2018), mihaylov80 (16th February, 2023)
    Aug 2016
    EURO-KOLCHOZ
    sensors can be removed?thnk you..
    Dec 2012
    Yes can be removed can also leave them
    pike's Avatar
    Sep 2013
    Quote Originally Posted by tugishrugish View Post
    dpf off Your file
    With this file, if suddenly the engine starts up, it will not go exactly.
  7. The Following User Says Thank You to pike For This Useful Post:
  8. #6
    Aug 2016
    EURO-KOLCHOZ
    WHAT YOU MEAN?
  9. #7
    xCata's Avatar
    Oct 2017
    Try these one.
    pass pm
  10. #8
    Aug 2016
    EURO-KOLCHOZ
    NOT WORKING ON YOUR FILE
  11. #9
    Aug 2016
    EURO-KOLCHOZ
    Quote Originally Posted by xCata View Post
    Try these one.
    pass pm
    on your file, even the engine does not start,I asked for a proven solution, not for testing because the car is very far away...
  12. #10
    Dec 2012
    what is the problem with my file which does not work what happens to the car
  13. #11
    pike's Avatar
    Sep 2013
    Exclamation EDC17C18 DPF OFF
    This is one point, what changes are made in the file from here.
  14. #12
    Aug 2015
    If you think try this one!
    Pass in PM.
    Best Regards
  15. #13
    Aug 2016
    EURO-KOLCHOZ
    Thank You all, problem solved, paid for good sollution and is ok, sensors are removed.
    Quote Originally Posted by pike View Post
